allenprimo913
- Joined
- Dec 27, 2008
- 63
hi guys,
i finally got my motor running after replacing the plugs and points and tested it on the water yesterday. it idles good out of the water and rough and dies in the water everytime i put it to gears(forward or reverse). i wanna see it run so i increased the idle speed just to get it running. at first it runs ok but rough then hesitate at WOT speed at aprox. 10-15mph. it doesnt seem fast enough for a 110hp. i put 6 gal. of gas and cruised about 3 miles out. While cruising i noticed a gas smell but i dont see any leaks visible outside, took cover off and i dont see any fuel leaking anywhere, the carbs, the fuel lines and the gas tank. because if there is i should be seing fuel spill inside my garage.
so i turned around and BOOM!! motor stop running completely. i pumped the primer and all i feel is air and no gas , my gas tank went empty that quick.
as i got the boat out i saw fuel coming out from the back of the back of the propeller. i dont know where it could be leaking from.
i dont notice the fuel leak if i start it at home at low speed but i can smell and see that the water coming out from the lower unit has smell and mix of gas but where could it be leaking. why is the gas coming out from the propeller and mixed with the water ? so i assumed it leaked all my gas more on high speed. does the fuel pump has something to do with this leak.
thanks for the help guys, i really need response , i like the boat and i plan to take my family this summer but cant do without gas.
i forgot to mention, i have finally got my service manual but i dont see any exploded view of the fuel pump . it has 2 fuel pumps with hoses going to the top carb and lower carb and while running at home i dont see any fuel leaks visible so im not sure where the fuel leaks coming from.
thanks again
thanks again
