1968dart
Thread starter- Joined
- Jan 21, 2009
- 12
I took the carb off my 1977 15hp Evinrude and soak it in sea-foam then blew it out with air and put it all back together. When I removed the idle screw I counted the turns it took to remove it. The thing is is that there is a rubber boot that the needle goes in to and its quite deep. So when I removed it I think I counted the turns coming out of the rubber on top the turn of the threads. Then when I put it back in I tried to do it the same. I ran the motor and it started right up and would run well and sounded good but when I backed off past shift to slow it would begin to die, and then would die if I went to far. I played back and forth put couldn't get it quite right. So does anyone know what would be the factory setting? I read to try to find out and don't know if its the same for my carb? All the way in, then a turn and a half out? I'd just try it and not bother asking, but is't that why this forums here?
Thanks for the help.
