nighthawk44
- Joined
- Jan 31, 2009
- 1
I have a question to see what others think, last weekend I was working on a looper 115 belive around a 2003 model. The person was saying it wouldent Idle right but would run WOT. The first thing I did was check the fire and compression, had fire all 4 cyl's and had 145 lbs of compression on all 4. I started the engine on a flushette and it idled about 2000 rpm but sounded bad, started pulling leads off the sparkplugs but wasnt hitting right on 2 of them, killed the engine with the keyswitch then restarted it, all of the sudden the rpms went to about 8 grand or higher, went to turn off the keyswitch it it stayed running the same rpms freaked out then went and pulled off all 4 sparkplug wires, still stayed the same rpms, was really freking now thought it was going to blow up, I finally went to the carbs and held my hands over them to flood it out and it finally died, my question is how is this possible?
no spark and kill it by flooding it out!
