Chris Hays
Thread starter- Joined
- Aug 14, 2007
- 87
Finally got around to fitting and starting my fully rebuilt engine in the boat, also rebuilt the carb, (new gasket kit, cleaned out all passages ports etc), engine will attempt to fire but will not run, still just guessing with the ignition timing, (set it static), as need it running to set it correctly. Once i finished turning over the engine after it would not fire, i looked down the barrells into the carb and gas was still trickling out of the venturi assemblies, flooding onto the top of the throttle plates??? I left the float adjustment alone during the re-assembly as it was set up correctly, why would it be overfueling?? My main question is with the fuel pump. How does it supply the exact amount of fuel to the carb without having a return to tank?? Is it set-up to supply the correct amount as the engine speed increases?? It seems as though its over fueling the carb and there is no where for the excess to go but down the throats. I purchased this pump brand new from a boat supply outfit on Ebay, the P.N. was correct and it looks identical to my old one. Any thoughts guys???
P.S. I also set the mixture needle out a few turns as it says in the book, but i also fiddled with this and it has no effect. Once i cut the fuel supply to the pump and tryed to run the engine to remove the rest of the fuel from the lines , it ran for about 3 seconds at a time, (which it would not do with the pump sucking from tank), although it would only run if revved, which is making me think its the pump even more. Ran out of time to play with it so thought id get some thoughts on this before i pull it out again.
Thanks in advance guys.
