Cam actuator on 1988 Evinrude 25hp
joho5
bolted on along with the shift handle on the inside of the cowling is a cam actuator that works along with the interlock system, and limiting the revs in neutral.
there is a zirk fitting that is also mounted right where this cam actuator needs to be put on, how do you remove those fittings?
thanks
Re: Cam actuator on 1988 Evinrude 25hp
zirk just unscrews, but what are you going to put there?
joho5
The cam actuator mounts over it...there is a hole on the actuator where the fitting goes through, then the actuator bolts on.
