quikstang347
Thread starter- Joined
- Jan 22, 2009
- 31
. hello every one ,
decided to get my mako it has an evinrude ocean pro 175 (1995) ready to run this weekend and take her out. everything has been fine with it , have had it several times no issues at all. yesterday i hooked up the tach and volts as well as water temp gauge . everything was fine put it in the water at marina fueled it up ,. started it and it ran fine . then the engine idle was fluctating up and down. a lil . turned it off and it would not restart . checked all the minor things . i have no power to the coils on one complete bank. resulting in no fire. i bought a new power pack and installed it and same thing no fire . i dont know if this will be of means to help with diagnosis. but i have to undo(cut) the black/yellow kill switch wires at engine for the thing to start. hook them up and it dies. check all the grounds and they are good , any help is greatly appreciated
compression is good and even. unhooked the low fuel pressure sensor and no difference. fuel; is coming out the exhaust , zero fire or power on the left side (if you are looking at it form behind) right side good. it does run but not very well.
