07Searay
Thread starter- Joined
- May 3, 2007
- 11
Hello again guys. I have a small problem. I have a trim gauge showing no movement at all at the dash. The problem is that I can't even make heads or tails of the electrical schematics supplied with the boat. BTW it is a 2007 SeaRay 185 Sport. Obviously, yes, the lower unit is moving. I tried to trace wires and everything appears fine, no loose connections, no blown fuses. I have also noticed that the 'alarm' normally generated when I turn the key on no longer works and I can't even find it to check it out. Anyone know where that thing is located? From the schematic, it appears that one lead leaves the gauge and travels to/through an alarm. Any help or direction would be appreciated. Thanks again.
