sheboyganjohn
Thread starter- Joined
- Aug 2, 2005
- 753
I am looking into getting a new project boat. I have found one that fits my needs that has a 72 125hp Evinrude on it. I am going to look at it on Tuesday but from the pictures it looks to be in good shape. It does have a few issues that I have reseached on here and know how to correct: cooling issue which will most likely be a new water pump and stuck in forward with eletrical shift so it will be either a new control box or one of the home made switches that I have seen on here. My qeustion is the compression. I keep seeing in post that as long as it is above 100 and with in 10% it is good. This motor has 105, 110, 125, 125 for compression. I plan on rebuilding all the carbs, new fuel lines, and running a decarb on it. Is the 105 cylinder an issue or will the decarb clear this up. And if it does not clear it up what affect does having a slightly lower cylinder have on the motor. In searching the forums I have never found the reason behind the 10% rule.
