Water Tank...Full or Half ?
tigerhack
Hello everyone i would like to know if its best to run my boat with the water tank empty half or Full ,what use it is to me apart from supply me with water when out boating and how much do that amount weight(28 gallons)?
pvanv
Re: Water Tank...Full or Half ?
Depends on how you use your boat. The water will go from fresh to stale to putrid as time goes by. But if you entertain, live, and sleep aboard, that water can be pretty convenient for cooking and washing.
Figure the weight is "a pint a pound" or about 8 pounds per gallon.
tigerhack
thanxs for your response ,Where can i find a water guage ?
RWilson2526
Cant remember the manufacturer but on "ship shape TV " this weekend they were reviewing a "flow meter" for fresh water tank. Rather than trying to measure the amount of water in the tank it was a flow meter that measure how many gallons have passed through the hose. when you fill your tank reset it and then keep track of how many of the 28 gallons have been used.
found it....probably pricey but I bet it works great
https://birdoff.com/watercounter.php
i personally have never filled mine, we don't use it.
jaxnjil
tiger; we have found that we get along fine leaving our tank dry[20 gal x 8#]
this is the same as one more person on board. we carry drinking water which we buy by the gallon and it is always fresh and easy to put in the frig or cooler. we carry about a gallon per person per day and this covers our drinking,cooking,brushing teeth ect. your usage may vary but this work for us
that said we boat on pretty clear lakes and have a raw water shower that we can use to wash down any thing we need,boat, sandy feet, pets, ect.
it is plumbed into the motor so we are able to get hot warm or cold water as needed.
in salt or brackish or muddy water i can see where this wouldnt work and then the tank would see more use
LOWRANCE 49-611 LMF-200 gauges have quite a few different sending units available. i think you can get one that will work in a water tank
jollymon
I found a very similar unit last year, and I think I have the info bookmarked on my computer at home. I will look when I get there. The only difference I can see, was the one I found was a generic unit, used for monitoring water usage at home, had the digital display option, and a way to reset meter to zero, I am not sure if measured gallons, or units, but would it matter, fill it and drain it once and you know how many units, you have in your tank.
The biggest difference I saw was the price, I think the meter was under $80, and the digital display under $40.
I will look tonight and see if I can find it.
SS MAYFLOAT
Several years ago I got rid of the 2 stock 17 gallon fresh water tanks. They were the original and the water that came out of them smelled and tasted nasty. We didn't even like using it to wash dishes or take showers.
I installed 6 pieces of 4"PVC water pipe 10' long. 3 on each side under the floor boards on each side of the fuel tank. I measured the amount in which they hold which comes to about 42 gallons. I have about 8 more gallons than before and with the water tubes below the water line, the boat actually sits higher with the tubes full of water vs how it was with the storage tanks that sat higher in the boat.
When my water gets low, the faucets will spit and sputter and that tells me it is time to go pump out the holding tank and refill my fresh water supply. Usually a full supply will last my wife and I two weekends.
Before I replaced the whole fresh water system, we also used jugs of water. Now that we actually use our fresh water system, it is nice to use the boat as it was intended. Its nice not having water jugs/bottles taking up much needed space.
If your planning on cruising or use for water sports, then you want your tanks empty of course. Less weight = less fuel consumption. If I was going to take a cruise for a long distance, then I would only start out with a half load and refill as needed.
chiefalen
Would it just be easier to just drain it, and then after you flush your motor just flush the fresh water tank, and when you go to leave on the boat, fill it with fresh water. How long could it take, the time to finish off a cold beverage ?
( wink )
tigerhack
Yes mayfloat ..the thing is i cant tell when the tank is half or not. thats the problem ,i could just cruise with it half .
tigerhack
what about having weight at the front to help stablize the bow ,have you heard of that ? a old fisher man was telling me about it is it true ?
jaxnjil
good call; forgot to mention that. allso on week or longer trips, wife buys the 2 1/2 gallon containers to use.
thats another reason we like the jugs. there are compartments for storage under the front seats and in the bow. we can distribute the jugs in for balance. the water tank is on the aft port side right at the back and next to the side so when we do fill it it will cause a list to that side as i have moved both batterys as far ahead and to the center line in the engine compartment so it will set level in the water. this way, when under way we use a minium of trim tabs. also takes a natural level set at anchor
