Re: Before it hits the water
My biggest issue with my 120hp was cold starting. It was just brutal. I checked over everything every season. Battery, terminals, poles, cables from the starter to the poles, the starter itself I had cleaned out, and it helped a bit. Also replaced the plugs every season.
When I bought it the guy who sold it to me fired it up in his driveway and it fired right away, no problem. Ever since then though I've had issues with the choking etc. Seems everyone has a different philosophy on when and how (long) to choke the engine before it fires. I've been told to keep the choke in until it goes, as well as choke it once, crank it over, and never choke again. Also, where to set your throttle for starting was never crystal clear. I played with WOT at times, and just leaving it at idle to start. I never had a tried, tested and true way of starting it and it became quite frustrating, especially when it was a cold, cold start. Eventually the battery would die out from all the cranking and I was hooped.
I'm not trying to scare you away from your engine, just sharing my experiences here. I have since upgraded to a Mercury Optimax and really look forward to this season.
There is a tonne of help on this forum, this is by the far the best place to be for information on outboards and boating in general.
Always remember that when you ask a question to post your engine type, model and serial number. Makes it a lot easier for guys to help you.
Good luck!
SSS
