120hp force reeds and exhaust plate, where to buy?
IMPATIENT 1
looking around the site and i can't find a spam section, so sorry if this the wrong place for this type thread.
i need a exhaust plate and reed valves for my 1998 force 120hp ob, who's got the best prices and can do paypal over the web? kinda need em quik:p sand bass are gonna start their run here soon:D like shootin fish in a barrel if you're on em:) i've gotta master gasket set on the way, not sure if it needs reeds or not but my research on this site says its possible so i may as well;)
Jack Daniels
Re: 120hp force reeds and exhaust plate, where to buy?
I have not checked but i would start right here on iboats. If the price is comparable and it usually is, its always good to support the forum and the help it gives you.
IMPATIENT 1
tried, they don't offer the plate:( i called our local marine dealer and asked for a plate, reeds, and fuel pump rebuild kit and he said "hold on, let me dig out that microfish":eek: i politely told him i had another call and would call back another time:D
Frank Acampora
See my private message to you
Can't help with the exhaust plate but if you mean the aluminum finned cover, I know it is expensive new--I think I bought one a while back for around 80 bucks.
IMPATIENT 1
frank, its just the plate in between that finned cover you mentioned and the block. when my wife gets home, i get the cam outta the car, get a pic and post it from work in the a.m.. i totally overlooked the crack in it when i pulled it apart. the plate was nice and straight, then overnite it warped all to hell:confused: guess it relaxed or maybe the cold, but regardless the crack showed itself better.
it may not need reeds, i'll get the plate on the way(thanx pnwboat;)) and wait on the reeds till summer. work is slow and i need to stash as much $$$$ back as i can right now, gm wants to close 500 dealers this yr:mad: maybe huntin a j o b soon:( may have to fish to feed the family, that'd be awesomeeee:D:Dj/k
Frank Acampora
That's the stainless steel baffle plate. It is not so expensive but if you have a friend that can weld, it can be repaired.
It sooner or later always warps because it is alwasys exposed to the exhaust heat. I have never seen a used one straight.
IMPATIENT 1
just so happens my neighbor is a master welder, but i'll go ahead and order a fresh 1, gotta wait on the gasket set to come in anyways. prob could copper coat the headgasket and reuse it(only has 8-10minutes on it), but with my luck it'd leak:rolleyes: i'll give that mercury p# for the plate to my local marine dealer and see if they can get it for me before the weekend. i'd like to put a couple hrs on the boat before i trust my family in it.
