Great Stuff Foam
Bob_VT
Re: Great Stuff Foam
No. I would not use it since it is so light duty.
erikgreen
I'm pretty sure great stuff is an expandable polyisocyanurate foam. Normal pourable floatation foam is a polyurethane.
Chemically I'm not sure what the exact differences are, but there will be some with regard to resistance to chemicals.
Great stuff is closed cell, which means it won't sponge up water, just like polyurethane foam.
But, great stuff is far from structural... it's very low density, so if your boat could benefit from extra stiffness, I'd use the polyurethane instead.
Probably the biggest reason not to use it is convenience. Pourable foam costs about $10 a cubic foot at low density, one can of 16 oz. great stuff is something less than a cubic foot (per the great stuff web site, it's a 3/8 to 1/2 inch bead about 335 feet long) which costs about $4-$8 depending where you get it. But you have to sit there holding the trigger on the can for 5 minutes per can to get it all out. Then get it spread into the space you want to fill.
You also can't install it under decks that easily.. if your stringers have no deck on them, it would sort of work.
So while I guess you could use it, there's not much reason to do so unless you already have a couple cases of the stuff lying around, and you don't mind spending a few hours spraying it in.
Erik
CAPTKEV85
I Have to fill all the stringers in. what should i use?
CAPTKEV85
web sites or dealers i should go to.
J. Mark
Prior owner of my boat "supplemented" the factory foam with a great stuff type foam.
It was waterlogged.
Use it at your own peril.
erikgreen
It's basically the same water resistance as the pourable foams, just usually more expensive and much harder to install.
Many of us have done repairs on boats with foam that was factory installed and was the "correct" type, so I think it's safe to say that most types of foam can get waterlogged if left to deteriorate in water a while. I know the regular pourable foam can.
For "approved" floatation, use pourable polyurethane foam from iboats or elsewhere... that's what it's for. Alternatively, some folks here have used pool noodles, empty soda bottles, blue and pink construction foam, or anything else they can think of.
Many of us don't want to use foam at all. It traps water near wood, which is usually a bad thing.
Erik
