As for hitting hard over at speed... I've been driving boats for several decades and have NEVER had an occasion to do such a thing. The only time I was in a boat when that was done was when I was a teenager and my sister's boyfriend was showing off with his runabout. He thought it was really cool, right up until the passenger seat (with me in it) came loose and fell on top of him. Of course, he was an idiot.
I don't drive a car at high speed and hit it "hard over" just to see what happens and don't expect to do such a thing while boating either. YMMV.
-BWR
Define "handles well". What happens if you throw the wheel hard over at higher speeds?
I guess hard over (implying turning the wheek to full lock)was a bad choice of words, but try making an abrupt steering input, ie an evasive maneuver to avoid a jetski, log whatever. If you've never had to do that consider yourself lucky. It is not something that you plan to do, but you don't always get to make the choices.
Same thing goes for cars. Sometime you brake, sometimes you steer, sometimes you do both; and an SUV that has been lifted to increase one aspect of it's performance will behave differently in a "panic" situation than one that was not lifted, or one that has been lowered.
Back to the boat - the foil doesn't differentiate between a straight line and a turn. If water is flowing over it, it is creating lift(and drag). In anything other than the mildest of turns(on glass smooth water) you risk haveing enough lift for the stern to break lose. Bow plants on a jetski are fun, in a larger boat with family aboard - unacceptable.
Thank you for correcting your terminology.
how would a foil stop cavitation as they claim in their ad?
Sounds like he doesn't use his tilt n' trim well when he's blasting off. The motor should be tilted as far in as it will go at idle speed, then when full throttle is hit, he should be tilting it up as he moves along, climbing over the bow wave quickly. My 17' bass 'n' ski boat with 150hp Mariner.......
First, he's only running a 115. Second, ventilation was prob the right word. I think everyone knew what I meantThird- he's a good boatman, but IMHO if he went back to a factory-ish prop he'd likely lose a few MPH and not have the venting issue anymore. But I don't hold it against cuz he sure can catch bass!
Do a little research and see how many people you find that installed a "foil" and did not like it and took it off. Now do the same for Smart Tabs. To me, that is more telling than anything else (I couldn't find any that did not like Smart Tabs).
See how many people installed one and actually used it correctly compared to how many read the promises on the package, then just bolted it on and headed for the water.
This is my first boat, so is that what this white plastic wraparound thing is on my outdrive?
