djarrett
Thread starter- Joined
- Jul 9, 2007
- 20
1984 yamaha 150 etln. Chasing a low wot rpm issue, i believe its down about 800-1000 rpm. I read the sticky about how to test your fuel line and bought a fuel pressure/ vaccum gauge. Carbs have been cleaned and it accelerates very smoothly, will idle as long as i want it to. Compression is 100, 105, 100, 103, 100, 102. Fuel pumps have been checked and i replaced one of the diaphrams as it was a little stiff. I did check the screen in the tank for a fuel restriction and it was very clean. The fuel line on the boat is 5/16, as are both outlets on the fuel pumps. Do i need to install 3/8 fuel line before performing the checks or is 5/16 fuel line sufficient for a 150 hp motor? I am very confident this boat came with a smaller motor and someone put a larger motor on it and i want to make sure the fuel line is the correct size. I have a seloc manual and can not find a line size recomendation.
When i first got the boat it would turn about 5100 and i don't know if it would turn any faster, i never tried but now i can only spin about 4400-4600 rpm.
Thanks
Thanks
