67 80 Hp evinrude lower unit leak
Status
Not open for further replies.
zarillus
I have a '67 Evinrude 80 hp with a lower unit leak,i got a leak by the prop and one comeing out of a little tiny hole.It's spewing chunky black fluid very thick.Where should i start looking,I had it tilted up for about two hours then when i tilted it down and i noticed black fluid spewing out of a tiny little hole.
Another question i had was i have another 67 60hp with a perfect lower unit will these interchange?
Thanks
F_R
Re: 67 80 Hp evinrude lower unit leak
Well we know the 60hp is manual shift, but how about the 80? If they are both manual, they will interchange.
Check the oil in the lower unit and see if that is the same kind of stuff you saw running out. If not, then it wasn't lower unit oil you saw.
zarillus
how can i tell if the 80 is manual shift it has a belt nera distributor if that helps
F_R
Look on the starboard (right) side of the motor. Do you see a shift lever? All of the 1967 60hp motors had one. But about half of the 80hp motors were electric shift (no shift lever)
zarillus
Serial number is E03695 and 80793M does that tell you anything.Sorry I can't get out right now to go look at it.
F_R
Yep, that tells the story.
80793 is a Starflite 80 Electric shift. Manual shift Speedifour 80 is 80753
Evinrude Boater
Likely not leaking either. They have a drain hole just below the water intake. Black goo drains out of the exhaust housing through that hole. It's just unburnt fuel mixed with carbon. That's what happens when the motor idles. It's normal.
zarillus
My leak is not coming from the hole in your picture it's oozing out of a small hole next to the larger bolts in your picture,i'm guessing the ones you take off to remove the lower unit.The size of the hole is is tiny
zarillus
I attached a drawing of the leak.
zarillus
I notice that same small pinhole on my 60hp,what is the pinhole used for
zarillus
tashasdaddy i read your post however i don't have a two stroke and im wondering what this hole that is leaking is used for.
Evinrude Boater
Zarillus, everything in 1967 was two-stroke, yours is a 4 cylinder 2-stroke. The other drain hole is as shown in my photo. You can see the oil stain on mine after it drained. This again is normal.
zarillus
Thanks guys appreciate the help!! I got 4 clyinder confused with 2 stroke.
Vlacovsky
So that drain hole in your picture is pretty much for “sludge” to drain in the lake?
MODERATOR EDIT: Please review the forum rule about posting to old threads.
Status
