Old evinrude sportsman, need info.
fastrepair
I have an old evinrude sportsman and I need some info like the year and oil/fuel mix and I would like to know the h.p. If anyone can help the serial number is 4412-02864. Thanx.
F_R
Re: Old evinrude sportsman, need info.
Fuel mix is 24:1 or 1/3 pint of TC-W3 oil per gallon of gas. Shear pin is part number 132092, 3/16" x 15/16" Aluminum.
fastrepair
Thank you both very much! I just got done cleaning the fuel system out(had very old oil and rust plugging everything up) and I replaced the sparkplug. All I should have to do now is mix the gas and start it. Fun project and easiest so far.
water pump!!!!!! if it has one.
kwp38burl
I'm working on a '47 4416 myself. I found that the years of gunk in the gas tank was removed in just hours with the help of a "paint and varnish remover". It cleaned the interior of the tank right down to the shiny aluminum. Just throw a cup or two in and slosh it around every 30 min. I would not use it on the carb, but it did a great job on the tank.
You had mentioned that you changed the plug in yours. I need to do the same with mine, but I do not know the correct plug# or gap. Do you have any information on the recent plug to use on a '47 sportsman 2HP 4416?
Thanks, Ken
fastrepair
Sorry I have not responded, I have not checked this site in a while. If you have not already got the #, it is a J6C, and I don't know the spacing I am running it at what the company has it set at.
