I just purchased a 1998 johnson 200 venom outboard that has a slight wobble to the prop/shaft. I pulled the drain plug and the gear oil has a slight foamy yellow look.. The boat went into gear and drove great. Wouldnt notice a problem unless you actually looked at it..
ANyways what am i looking at for a repair.. i can pull the lower unit off myselft.. i was looking into buying a used lower unit. I found a few johnsons here locally with a blown powerhead. one is a 94 175hp and one is a 2000 OMC, Evinrude, Johnson lower unit that was taking off a 250hp outboard motor in good condition. 25inch shaft.
Problem is mine is a short shaft... will either of these work? they want 375 and 300 for pricing.
thanks
thanks
