What year is my 2 Stroke Mercury
Grader1
I am new here and have a problem finding out what year my motor is. It is a 15 horse power and I need to know where to look for the sn#. these are some of the numbers I found under the hood...010788
42366
881-9727-c
I do not know if any are the serial# or not.
Any and all help is greatly appreciated.
Grader1 :)
mthieme
Re: What year is my 2 Stroke Mercury
You are looking for a 7 digit number starting with either 1, B or C, assmuing this is a US made motor. I have seen a single digit prefix before this number.
There could be a plate/sticker on the mount, also on the side of the carb is a little shiny disc, either of these two places will have it.
Grader1
Thank you for the Information.
Grader1
Grader1
I have hopefuly obtained the correct #'s B316853. I hope this is it.
Thanks,
Grader1
Grader1
I am new here and have a problem finding out what year my motor is. It is a 15 horse power and I hope these are the right numbers B316853 any help would be greatly appreciated.
Grader1
mthieme
That's a good number...1988
Grader1
Thanks Again for all your help.
Grader1
beemerbear
Re: What year is my 2 Stroke Mercury serial (407828)
I bought a 7.5 2 stroke Merc (407828) for my sailboat. It has been sitting in a shop for 10 years and not started. What years is the outboard? What should I do before starting it so nothing gets damaged?
sitkamick
I too have a Mercury outboard that has been hard to identify. It has been painted all black but I have the Serial number (0B187492) I don't know for sure what the HP is or the year it was built. Being a newbie here too I hope for the best. Thanks for any help.
Regards
sitkamick
Fun Times
Regards
sitkamick
ENG: 0B187492 Model Number 1008226
1986 MERCURY 8 ML
Service manual Part number from MerCruiser is 90-827242R02 - 6/8/9.9/10/15
sitkamick
Boat Tech
Thanks so much. Is the motor a 8hp? I am not sure what the ML stands for as well. I might be out of luck for getting parts. The shift is in the tiller arm and when I twist it, nothing happens, it just keeps going around with no stops. Can't get it out of gear to start it. A guy told me that they only go back 15 years for stocking parts for the tiller and shift part of it. Possibly I won't find any parts.
Thanks again.
Regards,
Mick
Fun Times
Boat Tech
Thanks again.
Regards,
Mick
You should be able to find your parts and answers you need in here.
http://www.maxrules.com/Merc_model_files/7p5-9p9.html
Or here. http://www.maxrules.com/merc_contents.html
(8hp) Yes your right.
(ML) stands for (M) ROPE START
(L) LONG SHAFT (20")
sitkamick
Boat Tech
Thanks again so much for all the help and information. It is truly appreciated.
Hopefully, I will be able to get the "kicker" going again.
Regards,
Mick
Colbro1
I am new to outboards, I have a Mercury 25hp s/n09605730, could you tell me how old this is and where i can get wiring diagram for kill switch and tuning tips
Regards
Colin
Colbro1
thanks for the info BDbill, assuming that i have to drop the leading zero therefore making s/n 9605730, then it appears to be a 1990 model
Regards
Colin
