Nandy
- Joined
- Apr 10, 2004
- 2,145
Re: Used boat advice for new boater
I have to disagree with you. If this is the first time you heard about a marine surveyor you might not be the best person to give advise about them. This is a link to a discussion about marine surveyor part in a boat acquisition and the needs for them.
http://forums.iboats.com/showthread.php?t=294414
If you are buying a boat under 1k you probably will not use one. You would not use one for every boat you see, just the one you are about to buy. They charge around $200 depending on the area. As you see, if you dont know anything or much about boats and you are purchasing a 4k+ boat it does pay to use one as if you buy the boat with rot and motor issues you are in deep. A good friend that knows about boat is way cheaper. However, just because a person has a boat does not mean I could check a boat right. It takes the right boater, the want that does his own repairs and if it has a few restorations under his/her belt then much better.
Colleen, keep looking, your boat is out there!!!
FIRST[ for me!!!! "marine surveyer" LOL!! never heard of one. and think you will spend more dollars out of pocket to use one. MAN! Look over the boat you want to buy,if it is or is not what you want, a middle man is just that, SOMEBODY THAT GETS PAID FOR DOING NOTHING. MY .02
