Prop Shaft
junior1113
Just Bought A Boat And The Prop Shaft Seams To Be Wobbling A Little What Does This Mean And Can I Fix Without Taking Apart
Mas
Re: Prop Shaft
You've got a bent shaft or bad bearings. The shaft should not wobble.
MAS
Barnacle_Bill
Re: Prop Shaft
Are you sure its the shaft and not the prop? It would have to be removed to be fixed.
Mas
Re: Prop Shaft
With an OEM manual, it's much easier and you're not flying blind. You'll need some tools too. Get the manual and with help from the forum, you'll get her done!
MAS
junior1113
Re: Prop Shaft
It Was In The Prop Can I Still Use This Prop
F_R
Re: Prop Shaft
How big a motor and how bad a wobble? It might shake the motor apart after awhile. Imagine a wobbly wheel on a car.
Barnacle_Bill
Re: Prop Shaft
The prop can be rebuilt and possibly save yourself a lot of money in the long run.
