You can often identify a component using the NTE online crossreference utility.There are some assumptions that need to be made when deciphering some of those part numbers and their crossreference will do that intelligently for you.Ron G
http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm
Just a curious question. Why do you want to replace them? They don't wear out, they either good or bad.
Nice going.You probably don't need to be told this but if you have room on the board you can increase the reliability of the repair by replacing the capacitors with a higher voltage rating for peace of mind.
If you do much repair work I have a source for an assortment of about 325 electrolytic capacitors for around 25 bucks.It comes in very handy when you have a suspicion and don't have a capacitance bridge to check them out with.
I will send the link to you privately if you are interested.Ron G
Saltwater or fresh?Update: The caps did the trick.
This amp has been a boat anchor for about 6 years, but now it works.![]()
Saltwater or fresh?![]()
