pulling to the right
joho5
my boat pulls to the right. There is no weight in the boat when I test it so its not improper weight distribution. Its a 14' 48" across jon boat...it has a 25hp tiller steer motor.
Could the only thing be where the motor is position on the back of the boat?
If its pulling to the right, would I just need to move it to the right an inch or two?
thanks
F_R
Re: pulling to the right
That is caused by prop torque. Is that thing pretty swift?
joho5
so its comon to pull to the right just a bit? Nothing I can do to fix it...its not bad, but after a while it can make my arm a little tired.
yea, its damn fast. I havent clocked it but I bet its close to pushing mid to upper 30's.
EMM
Adjust the trim tab to counter act the torque. It is the small tab near the prop. Use small increments until it no longer pulls.
joho5
I dont think this motor has an adjustable trim tab.
25 does not have adjustable trim tab. you can tighten the swivel tension some. my 15 use to wear my arm out, on long runs.
EMM
I have a 25 tiller steer and it has an adjustable trim tab.
joho5
this on is a 1988 and it doesnt have any adjustments for the trim. Would the whale tail fins be a cure to this problem?
I am not a big fan of the look of them, but if the boat would plane better and handle better, I will get one.
no, what you are dealing with is torque steer. rotation of the motor, want so force the motor to turn. very common, even worse i bigger motors, the reason for the adjustable tab on them.
joho5
so if I dont have an adjustable tab, what do I do.
Can a tab be added?
tighten the tension on the transom swivel. it will be a little hard to turn, but the motor will be easier to keep straight.
