My brother in law enlisted me to help him after he bought a new lower unit for his motor. The lower unit was a 1980 model but he was assured it would match up. This outboard is model #70ESL75E. The reason he replaced the lower unit was because when he bought it, he did not realize the lower unit had no oil in it and trashed the bearings, and the water pump ended up toasting also. Because of the way the old lower end water pump looked, he decided to put a new one on the lower housing he just bought. All fine and dandy, we put it together and put the lower unit on. Now it seems like the driveshaft is binding when we try to start it and when we pull ithe lower unit, the driveshaft is hard to turn with the water pump on it. We take the water pump off, and the things spins like a champ. Put it back on and it spins with a little difficulty, but when we put it back on, same thing. Take it back down and the driveshaft is harder to turn than when we put it back on. We are stumped. He turned the engine over without the lower unit on and it turns over fine. With it, it seems like it bogs on a stroke. We verified the exhaust on the lower unit is clear. My only thought was that maybe he is cranking down the water pump housing to tight (I learned when I met him not to try to do anything for him, cause his way is always right, so I just help with what he wants). Any thoughts as to why the driveshaft is binding on us? We compared the old pump with the new to make sure we were not installing it backwards...other than that...I am starting to love even more me trying to fit an engine in a car it wasn't designed for, it is seeming alot easier.
Thanks in advance for your help.
