Re: Tow Vehicle tire pressure
It also gives longer tire life. When it comes in contact with other materials, oxygen causes oxidation. Oxidation can make rubber brittle and cause it to lose tensile strength. In addition, at high temperatures and pressures, oxygen reacts and damages inner tire liners and belt packages; nitrogen does not.
Nitrogen is all around us... the air we breathe is 78% nitrogen (as mentioned above), 21% oxygen and the rest is small amounts of other gasses. When it comes to tire inflation, nitrogen has many advantages over oxygen. With nitrogen tire inflation, improvements can be noted in a vehicle's handling, fuel efficiency and tire life through better tire pressure retention, improved fuel economy and cooler running tire temperatures.
