Ostsideend
Thread starter- Joined
- Feb 2, 2009
- 116
Re: 5,7 Mercruiser overheats
Hi sarantis,
tomorrow i will put 1 bar of pressure onto the internal cooling circuit. With an medical endoscope i will try to see via #7 spark plug bore where the leaking comes from. If it is not visible, i will disassemble and check for mirco cracks with a special spray or other hints for leaking reasons.
Press me the thumbs as we say in germany for luck. Hope to find a failed gasket only.
With best regards
Oliver
Dear Oliver,
A lesson i took last 3 years is never to disassemble anything unless you cover any possible test to get more certain.Many things e.g a gas pump may work fine and after disasembly may leak.The test i did ,revealed my problem at dock ,not under load.I sugest you did it using a big barel to sinkthe outdrive (on mufs you ''ll certainly find bubbles ).Good luck!
Hi sarantis,
With best regards
Oliver
