Arizona Bass Fishermen's Top Stratagies
Starcraftguy1
I'm in an aluminum boat only bass tournament every month.I'm good for 2 to 3 bass in a day that are worth keeping for weigh in.I have picked up a third place.How do you professional guys catch so many fish.If I am not in a tournament I will use a slip bobber and kick everyone's butts.But when it come to just chucking lures it gets tough.Give me some info please.
fishrdan
Re: Arizona Bass Fishermen's Top Stratagies
Not a bass fisherman here,,, but the times I have gone after them I just threw tried and true lures with pretty good success, Zaraspook, tandem bass spinners, Hula grubs, small crank baits that match shad bait fish. Look for some structure and work it, if no success move to a different; section of lake, type of structure or depth.
I might just be lucky though,,, took out one of my bass fishing friends and skunked him 4-0 when he asked if I had another one of those cheap $1 2" white crankbaits :D
Mark_VTfisherman
Depends on the day. I am not a great bass fisherman, but my fishing buddy is- he's won a number of state tournaments.
What I have learned from him is that you need 5 or 6 go-to methods- carolina rigged "creatures", a jig program, a texas-rigged worm technique, a top-water selection and cranks at a minimum. Just practice up on them when not fishing for money and then when you find one method not working in a tourny, go to another until you start picking up fish.
Of course, I am with you as far as broad experience with methods, but my friend sure makes it look easy :) though I am getting better.
channelcat13
Hey all. I too am far from a professional fisherman, and mostly I fish bait on ultra-lights (or medium/heavy if pike or cat). My all time go-to lure for largemouth and especially smallmouth is the 3 1/2 inch rootbeer colored gitzit tube bait fished on a 1/4 ounce or less jig head. I have tried lots of different colors but nothing seems to outfish the brown with red flecks pattern (I think it imitates so many terrestrials, aquatics, crustacians, etc.) I like to fish this jig on 4 lb line with a medium/light outfit if I can get away with it. I usually fish 4 lb even if I can't and suck up the cost of the lost tackle as it gets thrown into exposed trees in the backs of the western coves of Pleasant or somewhere else. I have caught nice bucketmouths on this and at least 50 smallmouth in the same day out of west clear creek, beaver creek, and impoundments in California (pyramid lake).
I just cast it out and very gently bump it along the bottom letting it "rest" for extended periods of time.
I absolutely love good old fashioned in-line spinners and have even taken bass on them (although its usually trout and panfish). My favorite spinner is a black roostertail (1/6-1/4) with a chrome blade (it kills the cutts/bows at the Ferry)!
Best,
Channelcat13
Starcraftguy1
I think that the biggest problem with me and bass fishing,is that I have two prostetic legs,so I pretty much have to sit on my bass seats.I can't run around the boat and jump from deck to deck.it makes it hard to cast into some of the spots as I am always positioning my boat.I have been trying to fabricate a seat that will let me stand all day,it will make casting easier.Something that I can just lean into and not sit.
Mark_VTfisherman
There are pretty rugged seats/leaning posts which can be mounted to your boat. They are tall and height adjustable as well. If your boat is wide and stable enough those style seats sound like your answer. You can look them up on Cabela's.
Some of the good techniques require being elevated i.e. standing to make them work. I am sure the seat will help you out a lot. Thanks for explaining.
CATransplant
Here's a secret: A lot of pro tournament anglers weigh in with less than 5 fish, too. It's interesting to read ALL the results from a tournament.
If you've won third place, you did good at that tournament. Lots of others didn't do so well.
I think the secret for you will be to lose the slip-bobber and fish with tournament techniques when not in a tourmanent. Find techniques that work for you consistently and stick to them. I've never fished Arizona bass, so I don't know what you encounter there, but there are fish to be caught in many places the "pros" aren't using.
An example is in a lake I fish in Minnesota, recreationally, since I don't do tournaments. I see a lot of anglers using techniques they learned on the fishing shows, and they're often going fishless. Me? I found out that I can drag a spinnerbait or a swim jig across the top of a big weedbed on that lake and consistently catch as many keeper bass as I like. Nobody else fishes that spot with that technique. For the life of me, I can't understand why.
One of the things a lot of amateur bass fishermen do wrong is to watch TV shows, then try to use techniques shown there in the wrong places. I see it all the time on the lake. They're so tied up in their electronics and the latest equipment and baits that they're not really fishing effectively for the water they're on.
Often, they don't know what the actual forage is in the lake they're fishing, so they're picking the wrong colors and baits. Then...they're fishing where the fish aren't, instead of thinking about where those fish might be.
I watched a guy fishing for walleye for about two hours on my lake. He couldn't figure out why he wasn't catching any. Back at the dock, we talked about fishing for a while. He said that he was seeing tons of fish on his locator and tried everything on them. Well, where he was fishing at that particular time, the fish he was seeing were carp. They hang out in that particular spot most of the day in large numbers, suspending just like the walleyes do. Now, if he'd dropped a big nightcrawler on a bare hook, with a split shot about 18" above it, into that depth, he'd have been hooked up right away with a carp between five and ten pounds, and he could have kept catching them there as long as he liked. No walleye, though. They were over in the coon weed, chasing golden shiners while he was annoying the carp.
Anyhow, congrats on your third place tourney finish. Eventually, you'll win one.
AZMinyard
I tend to pull in 4-6lb bass from Bartlett and Pleasant on 3" curly tails. I leave my house at 4 on Friday afternoons (when working from home) and catch 3-4 fish and am in line at the ramp at sundown. The last time I was out at Alamo I pulled 8 about that size out on the same.
The method seems to be the greatest thing to change up and find what works. Some days its all about flipping to the shore and following the bottom down - other days its top-water action, could be both depending on the time and conditions. The topo and habitat maps come in handy as well.
I risk the wrath of the forum here, I am sure, but I also recommend Spider Wire or the like especially if you don't want to continually stop and tie a new one on. My fishing buddy talked a lot of smack about me using it, until I was still pulling fish out and he had gone through 4 poles. Just my 2 cents.
Good luck, keep us posted on your results!
Starcraftguy1
Az. It sounds to me like the curleytails would have worked great last weekend.Do you use a jighead?What weight?Colored?I make all my own lead things jigs,split shote,slip sinkers.I took 10th.There were 30 boats.We did not take my Bass Tracker took my parners new boat,he was so scared to go near the rockes to get my stuck lures out that in 4 cast I lost $15.00 worth of shad rap X's.lol.He never catches any fish,If he did we would have got into the money again.He helps me with the boat launching and trailering,and driving,that is always worth something to me.I really like the idea of the curlytails though.Thanks
Mark_VTfisherman
There was an article in InFisherman about Rick Clunn at the 2007 Lake Champlain tourney- said he generally only uses one pole and reel. For every method. Every lure.
I was talking about that with a friend yesterday (a bass guy who has won some state tournaments) and his comment about lures and methods and "one option" was that the only way to gain confidence with a lure or a method was to take everything out of the boat, and fish the same lure, rig, or whatever, all day. By the end of the day you will figure it out. Then you practice what you learned- it becomes second nature, and you move on to another method and incorporate that into your practice.
OCD? Maybe, but I have fished a lot with him and he catches fish. Oh, and Starcraftguy1, he has scratches on his boat :) You are right- scratched boats get fish.
AZMinyard
For bass I go with a 3" chartreuse curly tail on a round head 1/8-1/4 jig. Whites and reds hit well also, glitter over plain. Rig with the tail up rather than down. I like attaching with a swivel, my buddy swears against it. We both hit about the same number of fish in a day, he looses more jigs but also use monofilament whereas I use spiderwire.
Nice deal with this set up is that it catches bass, crappie, sunfish, stripper, pike . . . pretty much anything aggressive. Stock up a couple sizes of jigs and curly tails and you are set.
Good luck! Let me know how it works out for you!
Starcraftguy1
Fishing is always better in my boat,lol.The livewell is bigger.These expensive boats only have nice looks,fast motors.I love my bass tracker with the 40 Mercury,I can fish 3 trips with the same tank of gas,my partners boat sucks the life out of us,lol.Next tourney is April 11th at Alamo Lake.And I know where all my stuff is on my boat.
Starcraftguy1
I figured out the standing leaning seat too.The guy that I got the boat from worked at a chainlink fense place,he had welded some pipes that attached around the botton of my springfield posts.They were for unbrellas.I shortened one of them,so it would just clear the seat,got a 4' pipe to go over the pipe sticking up to put the unbrella into,and attached a butt seat horizontally.I just lean against it,works out great.
Mark_VTfisherman
Cool!
Thanks for the update. If you ever get lost and find your way to Vermont...love to fish with ya.
Starcraftguy1
VT I will be going back to Pennsylvania in a couple of months.We will see if I can find Vermont,lol.I would love to go out in a different place,Thanks for the invite.
Try a 4" lizard TX rigged with a 1/8 oz (or smaller if you can throw it) weight let the water color dictate the color of your bait. My favorite colors are Red Bug, Cotton Candy, Water Melon, Water Melon Red, Green pumpkin and June bug. I would use 6 or 8 lb test line unless the water is stained. I would also try a 4" finesse worm in these same colors.
These two lures will catch fish in just about any condition and they are great lures to catch pressured fish. Don't think this is just a small fish bait either, I've caught them over 8lbs on both.
Good luck I hope you catch a pile of them!
Mark_VTfisherman
Well, if you have the time and don't mind the drive. (depending on where in PA you are 6-7+ hours to 11+ hours from me. I hit Wilkes-Barre in 6-1/2 hours once...)
PM me when the time comes if it is a chance for you- I will send you my phone number and we'll see if I can be available the same time you are.
