Gas and oil mixture. now water in the lower unit?
zach103
I have a new to me evinrude Model: 55773D Serial: E0006724
i wanna figure out the gas and oil ratio so that i can get it runnin.. where can i find this.. is it the same for most engines?
sorry for the newbie question.
JB
Re: Gas and oil mixture.
Ahoy, Zach. :)
That is a 1977 55HP.
Fuel mix is 50:1, 1 pint TC-W3 rated outboard oil to 6 gallons 87 octane unleaded regular.
Good luck. :)
ob
The model number indicates a 1977 model 55 hp engine.Mix is 50:1 using TCW-3 oil.
ooooops.JB beat me to it.:)
zach103
Thank you very much guys.. hopin to get it runnin soo. ill get a nice video of it for you guys :)
zach103
Jb or anyone else.. i know i need lower unit lube . i dont wanna take it out than just leave it empty with the weather so cold.. so how much do i need for my . 1quart?
Rick.
That will probably fill it twice. Rick.
Rick.
The first time I did it I used a bottle like that with a tube and squeezed it into the fill hole and it was hard as h___ and I made a big mess. Yes get the pump but it can still get messy. Rick.
zach103
ok i got the one with the pump.. it come with 2 quarts but i dont mind i have a johnson on the larson so i can use it on there.. alright another newbie question. i know theres a lower and upper plug for the lower unit. and you drain it from lower and fill from lower but i understand you need to get the air out .. i found one right at the top of the lower unit.. right under the blue lines on the bottom there.. but were would the upper one be. is it a smaller plug?
zach103
WOW Thankkssss for the link. im pumped lol.. you have no idea.. i have a manual for the johnson/evinrude 73-91 but 60-235hp.. so i was trying to go off that .. but now i have this.. SWEET.. ok so i found it now.. didnt think to look that far down stupid me
zach103
so here it is thats just some that i let out.. some water came out first.. the motor that hasn't run in more than 5 years.. the stuff that looks like sand to the left and al that other junk was already there.. just the water and that lube with the bubbles came out
Rick.
Re: Gas and oil mixture. now water in the lower unit?
Well that isn't the end of the world. If I'm viewing your picture correctly you drained only a tiny amount from the leg and some of that was water. Frankly I don't see a lot of water in the picture but for sure there is some. I would say drain it completely, fill it with fresh oil, use new plug gaskets and close it back up. After you have used the motor in the water a few times re-check it by just opening the bottom screw and see if water is present. Many times the water is there as a result of the plug gaskets leaking not the gear case seals. Rick.
zach103
ok sounds good. .. Thanks alot man :)
