Where to buy trailer tires locally?
halas
Where is the best place to buy 12" tires for a small boat trailer locally to avoid the shipping cost? Lowes had them but only 5 lugs. I need the ones with 4 holes. Just fixed up this trailer and the tires are cracked, wheels rusty.
Any of the car tire places have them? Would even buy together with the wheels if reasonably priced.
timdan94
Re: Where to buy trailer tires locally?
tractor supply, harbor freight, and our super walmart have them.
Landscaping Wiz 808
Hi halas - You can get the tire/rim combo at Walmart. I picked two 4-hole tires/wheels there a couple of years back for around $100. I live in VA, but I'm pretty sure all Walmarts will have them.
chicknwing
Northern tool sells them as well!
TC
Barnacle_Bill
Where is locally? I get mine at trailer shop. Prices aren't bad either.
If you have a farm store in the area, they will have them and usually at better prices than even WalMart. They will also stock just the wheels, tires, or the combo all mounted and ready to go.
Shizzy
Ensign
as already mentioned, tractor supply, northern tool, Fleet farm etc.
i buy from my local tire dealer, then i get free service, for flats, etc, also free balancing. always balance your trailer tires, cuts vibration, bearings last longer as doe the tread.
lckstckn2smknbrls
Menards is where I bought mine. In the few months since then the prices have jumped quite a bit.
blouderback
Pep Boys, Sears, Walmart, KMart.
mthieme
Can't answer the locally part since I don't have the first clue what part of the world you're in. But, aside from the other popular responses, I've bought many tires from Rusty' Bore's Tire Store for my tractors which includes 12"ers. The last pair was 5.10x12 and good for almost 1200# each.
http://stores.shop.ebay.com/Rustybores-Tire-Store__W0QQ_armrsZ1
halas
Thanks for the great suggestions.
I am in Cleveland Ohio and got a pair of wheels at the Sup. Walmt. "CARLISLE" tires/white wheels 5.30 - 12 size.
$60 each. (slightly smaller outside diameter than existing old wheels on trailer)
Rated each 855 pound capacity 1700 lb total at (55 PSI) cold pressure.
Since my whole rig with trailer only weighs under 800lbs. I thought I use lower tire pressure maybe 45 PSI.
Is that a good idea?
NYBo
No, leave them at 55 PSI for the least rolling resistance, unless you get too much bouncing.
stevenj
You're in Westlake ohio, I grew up there. Live in Elyria now, Call Tractor
supply in Amherst, Just out west on I-90 at the route 58 exit.
(didn't read all posts befere replying, glad you found them):redface:
