Re: Can this do better
You are All great resources for assistance, let me tell you how my boat runs on a typical 1 to 2 ft chop. the finger lakes are almost never flat water and the chop is something I have to deal with all the time. On lake Ontario, it's an inland sea, which sometimes translates into white caps of 4 to 6 feet or long swells of 4 or 5 feet depending on the wind. Either way, I stay at the dock and drink and eventually fall down. It's safer and people will at least find my body.
On a 1 foot chop I can get the boat on plane and run it at 1/4 trim. As I move to 1/2 trim I will start to "porpoise". If I'm alone, I'll deal with a bit of bounce, cause that's what guys do. until one of the tackle boxes pops open. If I have someone in the boat with me I can move then into the bow and stop the porpoising. Here I'm getting about 24-26 mph at about 3500 RPM's.
With my hull in a two foot chop, If I go much beyond 3100 rpm's trimmed so I'm on plane the trim meter is somewhere between 0 and 1/4 and I get about 17 or 18 mph as measured by GPS. Faster, than that gets 2500 pounds of boat an people airborne. Pretty to watch, painful to experience.
When I said stern heavy (stern is the back right) I meant that the boat sits in the water real low at the dock, the bilge out flow port is about 2" above the water line. I swear that some days on rough water where I've got the boat trimmed so the bow is riding high so as not to get waves over the bow, that water is coming in through the bilge hose, seems that on those days I dump about 2 or 3 gallons of water out of the boat when I take out the but plug.
I trailer the boat everywhere. Looks like in another month when the ice melts, I'll give some of these suggestions a try. I like that check the marks on the hub and prop for slipping. The engine always seems to run so smooth, never rough, though It does cavitate quite a bit between 500 and 2000 rpms no matter how I trim it.
