Suzuki DT4 clutch rod adjustment
texakahr
Okay, the clutch rod bolt broke on my DT4 outboard. Had to sail back into the slip! Anyway, I pulled the motor, dug out the broken clutch rod bolt and connector parts, and replaced with new parts. Problem is I don't really know where to set the clutch rod connector and don't remember the position of the F-N-R lever at the time of failure. I tried a few settings and the prop doesn't seem to spin with any significant power. Also now when the motor is running, it looks like some water/air bubbles are coming out from the clutch adjustment plug (big rubber stopper). Any advice or suggestions most appreciated since my girl is expecting to go sailing this weekend!
newster
Re: Suzuki DT4 clutch rod adjustment
I think you have to have the clutch in forward in order to properly attach the nut holding the rod together. I had to do this on my dt8c when I changed the impeller and I didn't know exactly how far to screw it in after I reattached the whole thing. At first, I had it too far up where it would barely shift into reverse while running and pop out. I then adjusted it slightly and it worked like normal. Trial and error for me. Hopefully you will get it right the first time.
texakahr
Thank you newster, I will try some more settings. Anyone have suggestion or concerns about the water/bubbles from the plug port?
emeric
hi i removed the clutch rod on my susuki dt50 and is impossible to replug the cam in the lower unit!!!
thanks
emeric
Steve Cook
same here, I did it last night
not much too it really... trial and error
and it IS easier if you put it in forward gear
