Grizzly Preacher
Thread starter- Joined
- Feb 10, 2009
- 8
I am extending the front casting deck on my Alum. Grizzly. I am using plywood of course. Low budget so not marine grade, but it is garage kept, so only water exposure will be while fishing on rainy days or washing down...
- If I use exterior grade poly urathane to seal it, should I still put a primer sealer down first?
- Will the outdoor carpet glue bond to the poly?
- I will be putting carpet down over the existing aluminum deck as well - Will the outdoor carpet glue bond to the aluminum or should I use some other type of adhesive on the aluminum section?
