1974 merc 115 compression
rosentreter
I ran the motor for 10minutes to warm it up with the water muffs on. I removed the plugs and took the compression readings. #1 140 #2 151 #3 150 #4 160 #5 159 couldn't get to number six.
What is up with that, is it carbon build up?
It always starts and idles okay at 1000 rpm. Is it still a good machine?
Thanks, Rich
JerrfyLube
Re: 1974 merc 115 compression
Numbers look fine to me...
Was it running bad or something?:confused:
emckelvy
10 to 20 psi diff in compression readings on an Inline Six is NOT good news!
I'd recommend a Severe Duty decarbonizing treatment (fogging the motor thru the carbs and also spraying in the spark plug holes with the engine tilted up) with Seafoam or equivalent then checking again. Even better, take 'er out after the decarbonizing treatment and run with a load of cleaner in the fuel.
Check out this carbon-treatment FAQ:
http://forums.iboats.com/showthread.php?t=158076
Take compression readings while the motor's warm. Make sure the throttle blades are fully open when you take readings or you're not getting accurate ones. If your compression readings improve some value less than 10psi difference between the highest and lowest, you'll probably be OK. But I would still monitor periodically so you can detect any deteriorating trend.
Be sure you pull all Six spark plug wires and you'll need to jump +12V to the yellow-wire terminal on the starter solenoid to get the starter to crank over while you're in gear/full throttle. Watch out for the moving prop!
Be very careful of sparks around the carbs; you can use an automotive-type remote starting switch or make up your own with cheap parts from Radio Shack.
Note if you undo the rear cowling bracket you may be able to drop the lower cowling down enough to get your compression tester in to #6 cylinder. Or get the special short compression gage Merc (and others) sell, which will screw right into any cyl with no issues.
You also might consider contacting a local dealer who's set up to do a leakdown test, which is a much more accurate indicator of internal condition than a compression test. After the decarbonization, of course!
HTH & keep us posted.........ed
Those numbers seem like really high readings. Usually they are in the 115-130 range on a engine that old.
JB
Sounds like an engine wanting to be decarbed. Very unlikely that there is any mechanical damage.
