I have a 1990 Evinrude 175. I have had the same quirk with it for the two years that I have been running it but it is now getting worse. When the engine runs at idle for any length of time it gets a little rough. Then when I start out to run at faster speeds it just sputters. It will go back to idle fine but will not run at high rpms. If I put it in neutral and rev it up to about 5000 rpm?s for a few seconds then put it back in gear it will go. When I run it fast it is just fine, but after idling I tend to have the problem. Could the fuel line be sucking air or have a clog? Could my carbs need a cleaning?
Thanks, Jeff
Thanks, Jeff
