Re: HELP!!!! 1966 johnson super sea-horse 33 electric
To check the compression, you screw a compression gauge into the spark plug holes and crank the engine over to see what pressure the pistons produce.
An auto parts store may lend you the compression gauge and harmonic balancer puller for free.
You need to get some sort of repair manual for this motor; the main library branch may have one. This isn't hard, but the first time through takes a bit of patience. Don't try to do everything at once.
It's best to go about getting the motor running systematically. Here's the order I do things:
Check the compression. The readings should be within 10 percent of one another.
Check the spark. If it's not good on one or both cylinders, then I put in new coils, points and condensers.
Change the water pump impeller if I don't know how old it is.
Change out the lower unit gear lube and make sure it shifts in and out of gear.
THEN, I try to start it in a barrel of water. If it doesn't run, then I know I have good compression, good spark, and all that's left is the fuel system.
If there is a problem with the fuel system, then I get a carb kit, disassemble and thoroughly clean the carb, and re-assemble with the new parts from the carb kit.
I can usually do all of this easily in a weekend, probably a grand total of 6 hours of leisurely paced work if I have to change the ignition parts, replace the impeller, and rebuild the carb. Broken bolts, now that's another story.....
