Re: minimum speed required to plane
With my tabs full down my 23 footer with a 20 degree bottom planes at 11.5 MPH GPS . . . 17 MPH with the tabs up.
I have played with this a lot, for tubing and wakeboarding you can't beat either Smart Tabs or helm adjustable as they seem to stay put at a given (low) speed much better. As opposed to always increasing speed if you start at the point where she just starts to fall over (wakeboard speed).
As others have said, this is not about wind, so forget that. Even high powered boats need a good jam on the throttle to overcome bow rise without tabs. If you want to really understand the whole deal try bumping the throttle 100 RPM at a time. Ignore your dash speedo, especially below 20 MPH. GPS only. This exercise will teach you a lot about boat handling in general. From idle go to 700 RPM, watch what happens, feel it, give it 15 seconds to do what it's going to do. Do that for 800, 900 RPM etc. You'll find out that she will probably not plane until around 2500 - 3000 RPM depending on how long you wait between throttle bumps.
On the other hand, there is nothing wrong with mashing the throttle 100% until she pops up on plane (you'll know). Then immediately start backing off the throttle to select a comfortable (AND SAFE) cruise speed.
This whole balance of off plane/on plane, speeds etc. is part of the joy of learning this wonderful obsession. Whatever you do, DON'T cruise around other boats in that no man's land with your boat's bow stuck up in the air. A) your wake will pizz off everybody, B) you'll get terrible fuel economy there, probably the worst at any speed and most importantly, C) you'll look like an idiot . . .
