BloodStone
Thread starter- Joined
- Mar 13, 2009
- 33
Hello all Newbie here;
An individual over at tinboats (BassBoy) recommended your site & I've been silently observing the forums and was impressed by how many no nonsense, knowledgeable folks participate in these forums. Anywho onto my questions..
I just recently recieved a 18 hp 1957 Evinrude Fastwin manual start with pressurized fuel tanks (good shape) & a 1964 Johnson 18 hp with electric start & standard tanks (fair shape) What I want to know is, how many of the parts are interchangeable between the two? Specifically I'm talking, starter, gear shifter, flywheel, fuel system conversion taking from the 64 over to the 57, etc..? The Compression test (done by me with a $200.00 tester) was done with the aid of a power drill with socket on the top flywheel nut. The engines were both cold. I've yet to have both motors up & running really (Evinrude for 5-6 seconds dry run, nada for the Johnson-even when injecting gas directly into the cylinders). I've also used an ignition tester on both motors & they seem to have decent spark but it may require further detailed examination.
Results:
57 Evinrude
Top 110
Bottom 110
1964 Johnson
Top 95
Bottom 95
Final question, if both motors ran equally well, which would you keep & which one would you sell & briefly why?
Thanks
Results:
57 Evinrude
Top 110
Bottom 110
1964 Johnson
Top 95
Bottom 95
Thanks
