Re: Do you have a spare tire for your trailer?
Yes always carry a spare, ihave one that stays in the truck at all times. Also good idea to carry a grease gun and simple tools to change flats, remove drain plug, also keep extra set of belts and plugs and wires and raw water impeller in the boat.
If you need a high rated tire guage for those high pressure tires, (my camper uses 80lbs) go to the nearest truck stop, such as a pilot or flying j or somethign if your having problem finding one at a store. They have long reached handles and are a dual chuck rated up to 130lbs (semi tires run about 100lbs) Perfect for those that have duellys or tandoms.
Good luck
Good luck
