Suprgrupr1
Thread starter- Joined
- Mar 17, 2009
- 2
Hey guys, just bought a 2006 176CC with a 2005 Mercury 90HP 4 stroke on a 2005 Road King Trailer. This was a boat I found on the internet where a guy was getting a divorce and had it on consignment at Marine Max in Gulf Shores. Had the dealer who was selling the boat hook it up to the computer along with a compression test and all came out fine and the boat runs GREAT!
However...
My navigation light on the front is not working. I replaced the bulb and that did not work. I don't think I'm getting power there. On the dash where I flip the Nav switch, it's not lighting red like it does on the other switches. When I look under the dash, there's 8 "prongs" for various wires to hook into. 4 on the left and 4 on the right like this and I'll label them 1-8 so I can describe what I saw:
Position #
1 5
2 6
3 7
4 8
They all have wires attached to these prongs except position 6. IS this spot supposed to be "open" or is it possible a wire became detached and simply needs to be reconnected? If this is not enough info, I'll take a pic and post it tonight or tomorrow after work and we can go from there. Figured this might be something real quick and maybe I missed a wire somewhere. The rear light works (the white all around one that you "plug in" on the stern).
The second question is to do with the courtesy lights that run in the back. One works the other doesn't. Replaced the bulb in the nonworking one and it still doesn't work. It did look like a little "green" material was on the bulb i removed indicating corrosion I would imagine. These are 12V bulbs.
Any help to get me started would be great.
However...
Position #
1 5
2 6
3 7
4 8
