erikgreen
- Joined
- Jan 8, 2007
- 3,105
Okay, since Oops! finally updated his hull extension thread, he has responded to my "I'll update if you will" challenge.
So, it's time to start talking about my new project. "New" in this case means "What I've been working on, one way or another, for five months". Not entirely on the boat, you understand.
Last winter I heated my double garage, which is detached from my house, was insulated as a shop by its builder, and is, for a number of reasons, too expensive to heat. Heating bills around $300 a month last winter convinced me I wasn't going to use the shop this winter.
Fortunately, I have an attached garage, too. It was a basic one car setup, with a bare concrete floor. It has the garage door at the front, 7 feet tall by 8 feet wide, a back door to the driveway area in front of the other garage, and one largish non-opening window.
I don't seem to have any "before" pics of the place.
The attached garage was outdoor temps in the winter. The walls were just shells... studs with sheathing and siding on the outside, and old paneling on the inside. No insulation in the ceiling. There was an interior wall between my house and this space, too. No wonder my heating bills were so high, even without the other garage.
So I decided that I'd remodel the attached garage into a shop space. This would give me space to build a boat in the winter, as well as helping keep the house warmer. It also would provide me a starting space to remodel again into a den or living room once I finished the boat build, and that would add to the value of my house, which is currently taking a beating due to the economy.
So... I started in October (actually earlier on and off) cleaning out the garage space. This included removal of a lot of the paneling, a shelf or two, removing items I stored in there, sweeping, and assessment of the structure and ceiling.
It turns out that the walls were only 2x4 studs, so I needed to make them thicker, to put in better insulation. I also needed a few new outlets wired up... the garage had a 220V circuit I could split and use provided I grounded back to the electrical box.
So I doubled the wall thickness by building another copy of the stud walls inside the old ones. I also removed a huge paper wasp nest, tons of spider webs, and a few old trash items like a 1960s soda can and misc nuts and bolts from the walls.
Then I installed R19 fiberglass insulation in the walls, and put in some outlet boxes and wiring to extend the existing circuit to a better spot, with GFCI protection (required by code since it's still a garage for the moment).
I also blew cellulose insulation into the ceiling (R49) after extending the light fixture (one bare bulb) to two other locations and wiring all three as switched outlets for fluorescent fixtures.
Then I painted the floor with a nonskid floor paint (light blue, it was cheap) after primering the walls. Washing the floor down for painting left a bit of a stain on the drywall, but I'm sure I'll have to rebuild part of it for a living room eventually anyway.
So, a few cosmetic bits later (outlet covers, etc) I still needed lighting and to insulate the doors and window. I covered the big garage door with a "wall" of 2 inch pink foam insulation. It helped some, but it wasn't perfect. I need to replace the door with an insulated one, or else remove it entirely once the boat is out of there.
I put up 6 slightly mismatched fluorescent fixtures, plugged into the switched outlets. I wired them with lamp cords, which is ugly, but easier than permanent wiring, and lets me move them if needed.
I re-caulked the window and the smaller door with 3m 5200 to ensure they were sealed against drafts... I figured why go half way on a seal
Plus it was cheaper than another trip to the store. Then I "frosted" the window and the small windows in the garage door with some white paint and covered the window with more 2 inch pink foam. I sealed the edges of the window and the back door with some spray foam. Then I covered the door with plastic just in case.
Whew. So after all that was done, the space was quiet and held heat pretty well. I didn't have it tied to the house's HVAC, so I put a small propane heater with an outside tank in to warm it before I started working.. it's too small, but it got me through the cold.
Then I installed lots of shelves, a door desk for cutting glass rolls, some old kitchen cabinets for more storage, and pegboard for tools.
So after all this you'd think my boat workshop would look fantastic. Nah, it just looks ok. I need practice with drywall I think. But, it's a warm, well lit space to work. I'll put in an exhaust fan out the back door when I start generating lots of fumes, and I want to run a couple more power circuits whenever I can get my house's electricals redone (they suck).
One end of the space:
The pink wall is a 2" cover over the existing garage door. It helped keep the worst of the cold out, although the walls on either side are uninsulated for that 8 inch space. Next winter I'm getting a new insulated door... especially since I probably have to take out the current one to get my boat out, once it's built.
Note the lovely outlet placement. I need to lower that last one when I redo the walls to take the door out.
That's a sheet of Arauco ply on the floor, nice stuff.
Here's a view the other way. It's a smallish space, only about 23 long by 14 wide, with the door end having about 3 feet less width due to a closet.
I've got the plans for my boat tacked up on the walls for reference at the moment. My drill press is in there for now, I was going to use it for stirring epoxy, but it's heading for the basement instead.
I took down my fiberglass cutting table to save space, also since I don't really need it... a roller knife makes cutting so easy.
That propane heater is gone now too, and I've re-opened the back door, which is also getting replaced soon.
Last priority item to build is the dust collector, since I want to keep dust out of the main house as much as I can.
Next post: The boat
Next post: The boat
