Re: What may happen if a nut fall down the distributor's hole?
Anything that can happen, has happened to you huh sarantis. The motor in the boat already, shouldn't be cause the dizzy wasn't in yet. And i assume you were going to start it on the crate / stand .
You have oil in it already, shouldn't cause you were building from scratch, the only thing that should have had oil in it was the oil pump cause you do know it had to be primed before you installed it.
Me i would drop the pan while it's on the stand right side up. meaning don't turn it over.
See if the nut is in the pan. Then reinstall the pan. Put a rag into any holes that are open, thats a given and something i always do learned my lesson the hard way 40 years ago. Never leave a hole open and bolts or nuts sitting on a motor, when working on it.
Tip when you get it all together leave the dizzy out and spin the oil pump. Then put in the dizzy, and run it on the crate.
Sorry to hear about your misfortune, but i bet for the rest of your life you won't leave any holes open anymore, price of experience
Good luck !
