Re: transom question
Are you measuring your transom depth on an angle, along the transom angle, or straight down from top of transom to bottom of the boat (keel)? Correct way is to measure the straight drop...have someone hold a long straightedge up against the bottom of the boat so it sticks out past the transom, then measure from top of the transom to that straightedge. My old Texas Maid (1962-63) came with a 20-inch transom. When I mounted two standard leg OMC outboards on it, they were too shallow. Had to lengthen both shafts/legs to put them deep enough so the props would bite. Of course these are older motors with the water pump higher in the leg than newer outboards, so I have to run them a little deeper. Measure the straight drop on your transom and see what length you come up with...the cavitation/anti-ventilation plate on the outboard (horizontal plate above the prop) should be even with the bottom of the boat, or thereabouts...1-2 inches either way. Post back and let us know what you find. Transoms can be cut, but that can alter/ruin the lines of the boat if you are interested in retaining its classic lines.
