Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
On my to-do-list I need to install and plumb the bilge pump.
Have an 1100 GPH pump with 1 1/8" outlet hose size. Have the 1 1/8" discharge fitting already installed on the starboard side gunnel about 4" below the rub strip.
What is the right way to route the hose between the pump and the discharge? It is a straight distance of about 3 1/2ft.
If I run the line direct (no traps etc), all the water in the hose length will run back into the bilge when the pump shuts off so the bilge will always have a few cups of water in it. If I incorporate a trap, will it result in an airlock and prevent the pump from moving water?
