Re: Standard Fuel Pump to Replace VRO
Yes you can use the conventional lift pump and a lot of 88HP models were sold that way. Your engine has both fittings, one above the other, so that if you plug the VRO pulse fitting and unplug the conventional, you can mount the lift pump directly to the intake manifold without a hose.
