external resistor wire volts output
gmendozatp
what should the volts be from the external resistor wire to coil on an 140mercruser
Re: external resistor wire volts output
Ayuh,... 8 to 10 volts...
gmendozatp
thanks im ready 11.64volt could i say my external resistor is bad
Dunaruna
If the points are open, you should see close to battery voltage. With points closed, you should see resistor voltage.
Me thinks your battery needs charging.
Don S
That depends on what your actual battery voltage is if you measure from + to - on the battery with your meter.
