Lower Unit Lube
jaredlj
I was wondering if anyone had any suggestions on what type of oil is best for the lower unit on a 92 evinrude 175hp
junior1113
Re: Lower Unit Lube
i use 80-90w penzoil gear lube on my 93 200
5150abf
Re: Lower Unit Lube
Gear lube is for cars, your boat motor isn't a car.
Use LOWER UNIT OIL only, it has additives to deal with water intrusion.
No need to get fancy, the stuff from Wal Mart works great and you should change it regularly, I do mine 2-3 times a season to keep an eye on the lower.
A quart of oil is $4, a lower is $800, do the math.
Re: Lower Unit Lube
Jared, On a motor that new, I would recommend synthetic marine gear oil. It is a bit better (IMHO) than the Dino stuff. If the motor is older, it is a don't care.
junior1113
Re: Lower Unit Lube
of coarse this penzoil is marine lower unit GEAR LUBE and can be bought at walmart for 10$ a quart
junior1113
Re: Lower Unit Lube
$4 a quart seams cheap are you buying used oil 800 for a lower must also be a used price do you work at a junk yard. giving advise i would also buy the pump ussualy comes with or seperatly that wy you can fill from the bottom up
5150abf
Re: Lower Unit Lube
To be clear, you said " 80-90w gear lube" which is entirely different than lower unit oil, you may have meant lower oil but you didn't say it and my telepathy is on the fritz this week.
And the price was an example to illustrate a point, the correct oil is much cheaper than a new lower, yes I know they cost more than that although I have purchased a used lower with a new prop for $145.00, been running it for 4 years now.
And no, I do not work at junk yard, I build extremely high quality pontoon boats and am a TIG welder by trade.
I would suggest when giving advice be sure you say what you mean, the wrong advice could cost someone hundreds of dollars, like using gear oil instead of lower unit oil.
