Prop selection ??
glasspoisoning
Hello I hope someone can help me decide what prop would best suit my needs. I am running a 25hp 1974 sportster on a 16' flatbottom jon boat it weighs 1050lbs empty I use the rig for commercial fishing and need to haul up to 800lbs of cargo often. I am looking for a prop that can lift my boat and still have a little go power I want something that will not over rev. when empty but can still lift her when she's loaded down. thanks for any advise....
Re: Prop selection ??
Hmmmm 25 hp, 2000# load + operator and you want "get up and go". Start by looking at the very top of this forum. You will find a sticky that is titled READ THIS FIRST. The information you gave us is useless because we have absolutely no idea what the performance of your boat is now. You need to establish a baseline for us.
glasspoisoning
The information I gave you is all I have. The motor is new to me and came with no prop. I do not even know what prop is standard I assume that would be close to what I need. I have a flat bottom hull and weigh around 2000lbs loaded. The performance of the boat is currently Nothing....I was hoping to have someone guide me in at least some direction on where to start. And I have read the posting on how to get the most out of my questions I just do not have all the info I need since the motor has never been on the boat....
Thanks
hwsiii
glass, I am showing a 9" x 11" prop for that motor if the gear ratio is 2.15 to 1. With this you should get about 22 miles an hour loaded up to 2,000 pounds. Hope this helps.
H
glasspoisoning
Yes that is very helpfull. Now I have a place to start....Does any one know why I was removed from the front page and my ad was made dormant? I read the Sticky post and did every thing I could to follow it?
The reason you were told to read the sticky was to determine what the wide open throttle rpm is on the engine at this point with whatever prop you have available (hence the baseline). It may be the prop you have is already optimum and changing it will only hurt performance. Your engine needs to operate at or very near the top of the manufacturers recommended WOT rpm band. If it goes over that you need a prop with less pitch. If it cannot reach that limit then the engine is lugging and will eventually develop problems. Since you have no way to determine WOT rpm, I suggest you install a "Tiny Tach". These are about 30 bucks and are easy to install. Only then can you optimize your setup. Without that RPM number you are only guessing at what the engine is doing. As you said, you want the power to tote the load but you don't want to over rev when empty. Those demands are at opposite ends of the performance spectrum and you can't have it both ways. You need to determine which way you run most of the time (loaded or empty). If loaded you prop for power. If empty you prop for a compromise between the the two or you prop for empty and accept the performance you get when loaded. You should now realize the importance of a tach in your quest for a solution to a problem that may or may not exist.
glasspoisoning
Silvertip Thanks for the help I'll see if any local marinas have a tiny prop and go from there. Thanks again...
