Bone1099
- Joined
- Mar 21, 2009
- 21
I have a 1990 25hp Evinrude that was given to me. Hung it on the boat opened the cowl and began my adventure. First let me start with all of th variables that i know. (Before I received it) It supposedly was running good then it was removed and stored for a while and then reinstalled. I am just guessing that it wasn't running very well at this point so someone was messing with it had the plugs out apparently reversed the fuel supply line and the primer pickup line (as this was how i found it) they were pulling the rope it was pumping the bowl overfull and out of the vent filling the compartment with fuel and (imagine that!!) caught it on fire. (Idiots!!) It appears that the fire wasn't very bad it only melted a few fuel lined and caused a bit of exterior damage to the primer housing. Seems that the worst of the damage was the small line out of the primer burned a bit and melted the plastic fitting closed on the end barb is still there. cleared the hole and the primer works. removed and opened the carb one side of the carb was full of Goo apparently engine was stored on its side. So i cleaned the carb all ports seemed to clean up pretty easily blew through all passages they checked good too thought to myself alright we're bout' ready to go reinstalled carb took it to the neighbors pond it started right up and idled reasonably well but it wouldn't accelerate so thought to myself main jet must be restricted. Repeat carb cleaning procedure removed main jet first and it was clear checked float level looks parallel to the body of carb. Needle seems to open ok. Reinstalled and returned to the pond Same problem although this time it will accelerate a bit and i can drive around the pond a bit but anything over 1/4 throttle seems to kill it I can manually choke it with my hand and it accelerates ok but manually finding that sweet spot with my hand while dirving circles in the pond and watch out for that dad-gum big rock over there in front of the pic-nic table that you cant' see but trust me it's there. I can manage to get almost full power for a few seconds at a time. think to myself ok ive' got trash so i remove it clean it and still to no avail. Sorry about the novel but i wanted to try and get you all the info I could. Any input is greatly appreciated.
