Can you tell which is positive?
Mark42
Getting ready to put the battery in the boat and noticed that the posts could use a cleaning. So I cleaned them. Then remembered how hard it is to read the + or - signs on the posts with the battery in the box under the transom cap.
Soooo.... Grabbed a can of spray paint and marked the positive post.
Yep, I am board and have too much time on my hands.... :D:D:D
Oh, yea, after charging and sitting for two days, the voltage reads 12.9volts. So I guess its just fine.
maxum247
Re: Can you tell which is positive?
Sounds like it's in good shape, marking the post is something more of us should do, I can think of several times over the years I've started to connect the battery cables backwards because I didn't identify the positive terminal correctly.
max!
Bob_VT
Yup you are bored! ;)
a70eliminator
800 CCA wow thats one BIG battery, looks good. Some guys prefer to loose the wingnuts in favor of stainless steel nuts tightened with a wrench.
fishrdan
Nope not too much time on your hands,,, if that were the case you would have painted the negative terminal black too :D:D:D
Actually that's a pretty good idea since your subconscious will probably always notice the red and think positive,,, without having to identify the + sign.
gunner1
I think it's as important to have your cables positively marked as well. Hook them up backwards and you're frying something!
Mark42
DOH! Wait a minute, I think there is some black paint out in the shed....
:D
matt9923
That's a good idea i used to do that all the time until my friend did the same and mismatched the colors and fried a few things in his dozer. I found it relay funny idk why he didn't. :D
I'm going to do that when i get my new deep cycle an motor i don't want to f anything up for a few years at lest. Do you have a plastic battery box? I'm thinking of building one out of 3/4 plywood and coating it with some leftover bed liner.
Matt
