Stripe Bass fishing..
Marchosia
Ive been wanting to striper fishing here for a little while but ive never done it nor have anyone i know who has, i know you can do a charter but i wanna learn how to myself an learn from others an get some suggestions so my question is...
What is the best/most productive way to catcn stripers as far as, lures and techniques and so on here in central alabama lakes being, lewis smith, lake guntersville, lay lake, logan martin..
thanks in advance..
a70eliminator
Re: Stripe Bass fishing..
We catch stripers on 6"-8" suckers tail hooked and tightline fished 3/4-1 oz slip sinker fished on the shallow edge of a dropoff in the early evening hours. You can catch them on a jig with a lip hooked sucker too, finding them during feeding time is the key.
bchaffin125
The best stripe fishing in north alabama is right below a dam. I have been stripe fishing all my life. I have caught whites and yellows. I don't fish for the hybrids (20 pounders). I understand that you cant eat the big ones. I use a green headed jig with white hair and sometimes i put a small tuffy minnow on the hook. I usually sit in about 4 feet of water and throw into 20 feet of water. I then drag the jig back towards the boat usually on some kind of drop-off. While dragging the jig try to use a bumping motion. The best results are when the dam is releasing the water and you can see the water swirling in front of you. I usually start this fishing by the end of January. We catch our limit of 2-4 pounders everytime we go. I usually fish below guntersville dam. good luck.
Starcraftguy1
Do you guys ever use frozen anchovies for stripers?Everyone in the State of Arizona does,Lake Powell,Lake Pleasant,Lake havasu and Lake mead.They all use frozen anchovies,hell I can't even get them to stay on a hook.I use pearl white swim shads,3"ers.But they catch more and bigger ones.
Starcraftguy1
The lakes out here where the stripers get caught are deep.They use green submersible craooie lights down about 60'.Like around the tires at the marinas.Maybe with a slip bobber.Everytime that I have tried I pull in my line after about 10 minutes and the anchovies are gone,lol.I don't hook them up right.But the light brings in the shad and other small fish and the predaters are under them.If we can get someone on here to tell us how to rig a frozen anchovie we would be in bussiness.
Starcraftguy1
Plus,the cut off the heads and tails and use them as chum.
fishrdan
Anchovie/Striper fishing 101 is now in session :D
#1 selecting your chovies, When you are buying chovies make sure they have not been thawed and re-frozen. They should be swimming around in the bag by themselves, not in a block. You also want to buy BIG chovies, not the pencil sized ones. You might have to sift through the stores freezer to find the best looking bag(s) of chovies.
#2 chillin your chovies, Keep the chovies in a cooler with ice and only pull out a few at a time to cut and hook. They should remain rock solid until you are ready to hook them. In hot weather I put 4-5 bags of chovies in a small cooler with a few pounds of dry ice, this cooler is then placed in a larger cooler and the gaps filled with ice. This setup can keep chovies frozen for several days. While fishing, remove 3-4 chovies from the "Deep freeze (small cooler)" and lay them on the lid of the small cooler,,, yet still inside the big cooler. This will allow them to thaw slightly, yet not turn to mush. Cut up chovies on the lid of the small cooler and leave the extra pieces for fishing later. Cutting up rock hard chovies can be difficult so use a strong knife or wait until they thaw a bit.
#3 cuttin your chovies, I usually cut them into 4 parts, head, 2 middle sections and the tail. Chum the tails and heads and bait up with the middle sections. However, sometimes the tail sections work good for bait as it looks like a shad.... And then there was the time when my buddy and I were running out of bait and had a contest who could catch the most stripers on an anchovy head. Think I won with 3 small stripers on 1 chovy head... So the heads can also be used as bait.
#4 hookin your chovies, I have seen 2 good ways to hook chovies for striper fishing.
A- tie a Mustad short shank live bait hook (saltwater style) onto your line and then bury it into a chovie section. The striper's can't see the hook,,,, but they can easily pick off your bait.
B- (my preference) Tie a snap swivel onto your line, push the shank of a treble hook through a section or 2 of cut chovie and then snap the baited treble hook onto your line. I usually have to 2 swivels/hook/bait on my line, separated by 12-24". YES, this is a lot of hardware to have soaking in the water, but you have a greater chance of hooking a fish and baiting up is easy. Plus, it's pretty cool when you have 2 fish on 1 rod.
#5 chummin your chovies, cut up the heads and tails into small 1/4" parts and throw them all around the boat (in the water, not in the boat itself :D). Don't chum too much at 1 time, just a few pieces every few minutes to keep the stripers interested in your boat. If there is wind or current, chum so the bait floats back to your boat, not away from it.
#6 fishin your chovies, Cast you line out away from the boat and allow the bait to pendulum down through the water, stripers can strike while it's sinking so be ready. Once your line is below the boat, keep the bait moving, move the rod to one side and then wait for the bait to follow, or rip the rod upward and follow the bait back down with your rod. Stripers like to chase and strike a moving bait. Also, fish at different depths until you find out where the hungry ones are at
#7 settin the hook, Stripers won't slam the bait most of the time and like to pick it off the hook so you have to keep your hand on the rod and line so you can detect them. I like to cradle the rod in my hand, with it perfectly balanced, so they can pull on the line without feeling tension from the line. You will feel, tap, tap, tap, tap, pull... Be ready for the pull and swing back immediately with a big 'ol Bill Dance hook set. Stripers are tricky little devils and you have to set the hook on them.
#8 lighting and boat position, Throw out 1-2 fishing lights to attract bait fish swimming around in the lake. I usually have the lights 5' below the boat to bring the fish to the boat. Stripers like to hang out in deep water and I normally anchor in 50-80' of water. Try a spot for an hour or so and if the stripers don't show, move to another spot,,, moving the boat 100 yards can be the difference between skunked and wide open bites.
#9 moon phase, I find it best to bait fish at night on a new (no) moon. This way, the lights you have hanging off your boat is the only light on the water. The bait fish congregate to your light instead of scattering around in the moon light.
Starcraftguy1
FisherDan,thank you.I will be at the lake this weekend for a bass tournament.I will fish at night for some dinner.This is the exact information that I needed.
Marchosia
ha well that is alot of information.. but i want be able to try it this weekend, im goin deep sea fishin, but defitinitly gonna halfta give that a try..
thanks for the information
i try
i fish lake allatoona here in ga.we troll umbrella rigs made by mack farr:)
dhall95
The only Stripers we can fish for is on the ohio river on the downstream side of the greenup damn.. Mostly all we see is huge yellow eyed hybrids! Fight like hell.. Had good luck with shads, and big swim-crank baits.. need to find a swirl, a lil dangerous with your boat though, be careful... gonna be my first time with my boat out there, hope its a blast!
raray1221
i fish several diferent lakes in Alabama, currently lake martin but mostly Smith. Finding shad on the depth finder fallowed by marking fish is key if your fishing lakes. In my opinion finding the fish can be the hardest, they constantly change. Also use shad, nothing in alabama works better, that is what they eat and it makes up almost 90% of their diet.
Marchosia
what part of smith lake normally is the best area?
Starcraftguy1
Hey Marchosia,I followed the instuctions of FisherDan and caught about 30 stripers late Saturday night,early Sunday.Nothing big,but it was like crappie fishing,lol.Very fun.2lb biggest.
Meadfisher
They way it was explained to me goes something similar to this (been a while, so bare with me), Since this is Lake Mead one must fish it as such, so I was advised to tempt the stripers whith what they are accustom to, so use Frozen Anchovies, but thats not the trick, the trick is to take your frozen anchovie and give him a once over through the bilge, the Lake Mead fish seem to prefer it, like A-1 on your steak.
:D
Meadfisher
Night fishing!, That is when we pull out the monsters, over near Kingman Wash on the Az side is great for that, I mean monsters, that are longer than the cooler :D, if you happen to catch them in a boil, its on!, an I mean on! @ this point patience has been given way to the birds,its more like quick slam your beer, because theres another one on that pole! Its really a great time though!
~ Oh BTW, everything Dan said is correct, just for the record!
~~~ PS Dont 4get to bilge that lil sucker.....;) ~~~
raray1221
hey marchovia, i was the one talking about smith lake earlier and just havent been on in a while, sorry about that. this time of year striper are literally piled around goat island. if you have a good depth finder slow troll till you mark stripers and generally right now free lines w2ork best but down lines will too. FIND SHAD. they are the best bait but are hard to get. As this water temp rises fish move out to deeper water so try down towards millers flat, as early summer season they shoould be in there thick. Dont waste your time trhough, ride and attempt to find them on the depth finderbefore you fish. Also on smith, fish lights at night, generally lights over 40+ feet of water, and again check many lights until on the df. Dont fish on the light but rather anywhere within 100 feet of the light. Good luck
Meadfisher
And if all else fails, try giving that lil sucker a douse through the bilge***
