Re: 83 Envinrude 25hp Water Pump???
I'd cross that bridge when I came to it. Hopefully the problem is in the lower unit. If there's an obstruction in the powerhead, I'd take the thermostat out and see what it looks like. Has the motor ever been run in saltwater? I'd try the water hose again with the thermostat out and see if it's getting to the thermostat. If I had to, I'd take the exhaust cover out and look there. If it's blocked in the powerhead, I might just bite the bullet and take the powerhead off and see if the upper water tube grommet is in good condition and then take the exhaust cover and head off and check all the water passages. But like I said, I'd cross that bridge when I came to it. Normally if all of your impeller fins were intact then there's a good chance your powerhead will be clear. Have your ran it into any sand on the bottom? Sometimes it will suck up sand and it can get in the water jackets and block them.
Hope you figure it out,
JBJ
